Bro the ground clearance seems good to me.. I think it's same as rolla.. Correct me if wrong
I believe there is a difference of 10mm in ground clearance of both cars.
Lately have there been any cases of theft related to Corolla after the introduction of immobilizer? I don't think so.
Car theft and car snatching are two different things. The immobiliser only adds another security layer for Car theft, however it doesn't do anything against car snatching.
However, this is a tangent. Let's take that up in another thread.
Most reported : XLIAnd priority is White colour
For City Until you upgrade your tires to at least 195/60/15, your car will hit every other speed breaker if only 2 people are sitting at the back.Corolla won't touch same speed breaker with full load on factory fitted tires.
Should I consider removing the mudflaps because of low GC?
Hmm thanks bro... But I think I wouldn't have to face any problem as I'm from Islamabad
I read the forums before buying my car....honda city 1.3 c.c manual 2013....also read alot about driving styles...n RPM meter...in 5 months...with proper book documentation my city is giving me 18.5 km/l within city with heater...having started AC yet.
[For City Until you upgrade your tires to at least 195/60/15, your car will hit every other speed breaker if only 2 people are sitting at the back.]
Thanks I will consider the advise. Will it impact the fuel average?
I'd suggest you to go for 1.5 city, since you won't have to spend too much on top and later on save some more and get the 1.8 corolla. If your daily driving is on a good road, comfort won't be an issue with Honda city. If you disregard the price difference, I'd go for the 1.6 Altis.
Does your car hit the speed breakers? Can anyone please tell does it has less ground clearance than eagle eye civic?What if compared with Vitz ground clearance?
I have a Suzuki Baleno and it hits the speed breakers with 4 or more people on board. But my new Aspire 1.5 MT with stock tyres does not hit any of those speed breakers even with 6 people on board. Ground Clearance of city is a bit less than corolla but it is still good enough to clear most of the speed breakers.
In islamabad didn't run into any issues yet Alhamdullilah.Vitz has lower GC I think
I think corolla is 0.25" more higher than city from ground
Because it didn't had immobilizer before January
Honda should've added immobiliser to City also
[For City Until you upgrade your tires to at least 195/60/15, your car will hit every other speed breaker]
Can someone confirm if there is any impact on mileage if tire size is increased?
Recommend size is 175 and max should not be more then 185. Bigger tyres are heavier and need more power so more fuel is consumed. Also larger tyre size impacts the suspension.
It will surely effect as 195/65R15 are also bigger I mean more in height and also more in width... This will have a negative impact on the fuel economy...Bro does Lahore also have Undeveloped and badly development roads and speed breakers?I thought the government has only worked in Lahore...In Islamabad and rawalpindi there's no issue for Honda city as its 0.25 inches lower than a rolla altis......
