Guys Kindly share ur experience of getting catalytic cleaned checked worst and best methouds share ur experiences as its almost in every vehicle we have this mostly jdms suffer alot @xulfiqar @babarhyd my experience was first time with some strange strong acid used by some desi mechanic i think it was toilet acid and i felt rattler after that best was with liqui moly cat cleaner its when u feed from intake.
g sir i know that i think rattle was broken pieces inside cat and after some days i can hear rattle in back dholi also ctric acid means tatri? i request @xulfiqar sb to verify it if it really works
If your catalytic converter is so clogged that the engine will not run, you have to remove the catalytic converter and either use special tools or replacing the whole catalytic converter.
what are u saying post is about cleaning cat convertor and worst and best experiences of cleaning process breaking cat will pop up the check engine light as secondary o2 will be blind
best way to kerp it clean is to run the car at highway motorway occasionally or adrenaline induced high rpm drive in local. ur cat ll never get choked
Very Bad Experience with my belta 1.3 2006 clean with acid and water running f9 only 2 weeks after 2 weeks after 10km felling load on RPM
and clean again with chemicals (Wilita) without water and acid now its pickup is good and sound perfect
https://toolwala.com/product-category/lubricants/wilita-lubricants/
Take ur car on highways or motorway off and on and drive on 120 consistently for minimum one hour. You will never need to clean cat with acid.
