Hi All ,
Can anyone of you please confirm which tire size is good for Totyota vitz 2014 considering millage in view , my stock tires are almost expired .
Looking forward for your support on this .
Regards,Waqas Arshad
185/65/14
can you please elaborate why it is best ?
Its your choice to think which is best. Original size for it is 185/65/14 and its sensible to go for it. Else put anything you like. Your car your choice.
Original size is 165/70/14, If you are okay with default ground clearance of your vehicle, then go for same, otherwise mostly experts here recommend 185/65/14 which is good in my opinion.
185/70/14
People also use 185/65/15 which is ridiculous for vitz poor 1.0L doesnt have power to pull such heavy wheels. In 14 inch best size is to go for 185/65/14 else stock which i guess is 165/70/14 but 185/65/14 is better than stock and it will not effect fuel consumption and drive much.
thank you for kind support i guess ill be going for 185/65/14 since its not effecting any sort of millage as well with good road grip along with ground clearance
Dear Waqas, Can you please share your experience with 185/65/14??? thanks.
i recently changed my stock tyres to 185/70/R14, ground clearance has improved, fuel consumption is almost same, only acceleration has dropped little bit......
