had a very small 'arm rest' on the LX 450
<strike></strike>
on long trips it can be little tiring of not having a comfortable arm rest, I was roaming in the junk yard noticed a LS400, luckily the interior was the same color as the LX and it had a bigger arm rest
The console is a complete piece in both cars and there is a plastic plate on top of which the leather top resides
<strike></strike>
The leather cover is held by a couple of Philips screws
took of the cover off from the LX 450 put the cover for LS 400 and used small wooden screws (they have pointed ends) using a small drill, drilled holes in the plate of the central console and tightened the screws
has to drill because the LS 400 console is a bigger piece and to tighten it to the plate of the LX 450 multiple screws had to be drilled
<strike></strike>
