@r1 your num off? I msg'd you two times no reply
The O ring rubber should be able to stop the oil, if not the most probably good quality O ring is needed if still not then Curil can stop it temporarily, but as per me its not a permanent solution.
Magix Depoxi is also a good option though
hehehehhe .... Curil is very good sealent and bears very high temprature, yes it would not be permanant solution and after every 3~4 thousand kilometer when ever you need to change the Oil Filter you will again need to apply curil to make it seal properly again .. Thats why I asked him if he did replaced the Challa.. becuase if Challa is OK then it must not leak...
With high temps curil came out like a rubber. So i did it with Magic Depoxi. When i opened cover after 6-7K it was still there solid
Yaar sim card was blocked after Hajj so many circumstances but now number is on
Darn SEXY.. What about finding parts?
Saved r1 official.. llolxxx
I want this disc brake for my GS150:'(
Well, In lahore all can be sourced from Bilal ganj, and the tail will be fabricated from fiber or Aluminim
Strange, Which curil paste did you used, curil cylender/head sealent becomes more and more solid as its heated. no idea about depoxi, must be good if you have used it.
Contact Vicky, MalikG, 12gauge..
yes it is Not satisfied with stock rear brake shoes either. So kindly suggest me some alternative. which bike's brake shoes are same as GS??? and which brand i should be looking for
Stock suzuki brake shoes
Aoa frndsI got my new cg euro 2 machine on 4th of this month and till now 800km are done .I feel some odd noise from clutch side and I think its present in most of new cg's so I went to antenna shop today but they said sir everything is fine and after first tuning everithing will b fine however I dont think so.and one more issue I observed that some kind of oil was leaking from the joint of rpm cable thats coming out from engine.i also asked the mechanic about this and he said its grease thats melting out and it will also b finebut after driving a few kms that oil was again leaking.actually m new to bikes and dont know much about bikes but I was not satisfied from there service.need guidance frndZ
Sent from my GT-I9100P using PW Forums mobile app
I think the best option is to get custom leather on its metal assembly, never tried it. but heard they have more breaking power than these ones
They cant do anything till first tuning. Better complete the break in period and then when you go for first tuning get all issues resolved
@vickytullai noticed it, my bike doesnt give white smoke while starting in morning or anytime, however there's good carbon deposit on exhaust tip
Kawasaki gto has same brake shoe
Ok frnd lets hope 4 the best
i have her0 70cc , its gear is too hard i have change its clutch plates it will lil bit ok 1 week but now again same problem with gear is too hard tell me any solution ...
