OK i will try
Just thought of sharing my retrofit work too..1.OEM D1S Valeo bi-xenon projectors.2.philips amber led patches used as parking lights. 3.OSRAM XENARC D1S bulbs.4.OEM Valeo D1S slim ballastsphilips leds 2 patches used in each headlight
Dear if u got PM from other party then u PM me. bcz i also want them to get installed in my ride which can b seen in my avatar
Called you a while back for a retrofit on margalla. remember? got any ideas for the front glass?
yeah i did some research on it. if you can easily find clear lens headlights then it will be best if not then i think making clear lens with arylic sheet will be the only option
headlights with clear lens are not available (not even Chinese websites), acrylic sheet is the only option, but there are no vacuum tables here to make the lens, now need to know how to make the damn lens
You just can't leave Pakwheels they said.
its easy to make vacum table you just need is 2 inch flange,plywood and two 2*2 foot frames and vaccum cleaner
got the vacum cleaner but i don't think the ones we have at home are strong enough for the purpose, mine shuts down if you block it or give it something strong to pull against (built in safety mechanism)
but it will keep working till it suck all air from the table and lens
cutomized for pw member
Simply love it !!!
their is one more method which does not require vacum instead you need to make is male and female mold to make lens. check the bellow link The Clear Lens Forming Thread
amazing... i would love to have these on my gli
Ho jaye fir?
Sent from my iPhone using Tapatalk
haan yaaar but i suck at electrical DIYs also i have no knowledge of h2 h1 one point 2 point bla bla
Pm'd
h1 is bulb socket and is one point
yup, i explained it to him. Thanks to you i do now have some knowledge which you patiently shared with me
sharing is caring good work
