Jeez guys.. give the guy a break... what is there to flame about? and mr.faiz.. will pressing "enter" help him? no.. and both of you with your obnoxiously high posts..
@madno9
here is the thing, you basically have an APN activated that is why your browser, facebook and twitter are redirecting to Cellular internet instead of Wi-Fi..
Firstly are you running Blackberry OS5 or OS6?
You need to go to options and go to "device" scroll down to the bottom "advanced system settings" then again scroll to the bottom to "TCP IP" and uncheck the APN settings enabled option... save and come out..
if you are on OS5 then open browser go to its settings and make sure you have "HOTSPOT" browser instead of telenor wap!
last.. Go to manage connections and under mobile network options make sure Data services is ON and while roaming is OFF! when you are done using wifi.. make sure you Turn data service to "OFF"
hope this helps! if it doeskin then let me know...
