NO.... What I Mean Is This Converter Only Allows Scanner That Are OBD-I/ OBD-II Compatible To Connect With Its Only OBD-II Port Input...! Usually They Came With OBD-1 And OBD-2 Both Inputs Types....But Some Might Need This Convertor...
Only OBD-2 Scanner Won't Retrive Data From OBD-1 System..But It Need OBD-1 compatible Scanner To Do So
Also I Am Not Sure If You Able To Get Any Live Data Feed......! So Spending On OBD-1 Alone Is Quiet useless....
OBD-II Is What Makes It Much Easier For You....On OBD-1....I Guess A Paperclip/Jumper Is Still The BEST...Not Worth Spending
