BMW 1 Series M Coupe
The BMW 1 Series M Coupe embodies the unmistakable M feeling in a highly concentrated form. Its in-line 6-cylinder engine with M TwinPower Turbo and petrol direct injection develops a maximum output of 250 kW/340 bhp with an engine-speed-oriented characteristic curve typical of BMW M cars. With chassis technology derived directly from motor racing, a power-to-weight ratio reduced to 4.4 kilograms per bhp and precisely optimised aerodynamic components including innovative air curtains at the front end, supreme conversion of superior propulsion power into thrilling driving dynamics is guaranteed. The BMW 1 Series M Coupe accelerates in 4.9 seconds from zero to 100 km/h and reaches the 200 km/h mark after 17.3 seconds. In the area of efficiency, too, it achieves top figures within its performance category. Its average fuel consumption in the EU test cycle is 9.6 litres per 100 kilometres, while CO2 emissions are at 224 grams per kilometre.
The outstanding sporty flair of the BMW 1 Series M Coupe is outwardly expressed by the athletic character of its body design. In the exclusively designed interior of the 4-seater, high-quality materials and an M-specific cockpit create the ambience of a premium sports car. In its standard configuration, the BMW 1 Series M Coupe displays the concept harmony so characteristic of M cars: able to cope both with the extreme demands of the race track and the diverse challenges of everyday traffic. What is more, individual preferences in terms of comfort, safety and infotainment can be fulfilled with a model-specific selection of equipment options also available for the BMW 1 Series Coupe, including the BMW ConnectedDrive program.
The dynamic proportions with which the BMW 1 Series Coupe proclaims a brand of driving pleasure unique within the competitive field provide the perfect foundation for the instantly fascinating appearance of the first ever high-performance model in the compact segment. Measuring 4,380 millimetres in length and 1,420 millimetres in height, the BMW 1 Series M Coupe is the both the shortest and the flattest model in the BMW M GmbH range. It is also 55 millimetres wider than the BMW 135i Coupe: the width of 1,803 millimetres is the result and the expression of a track width at the front and rear axle optimised to enhance driving dynamics in a way which is specific to this model.
The design of the front end impressively reflects the outstanding performance capabilities of the BMW 1 Series M Coupe. The powerfully shaped front apron forms a homogeneous surface, dominated in the lower section by three large-format air intakes. In order to optimise the aerodynamic properties, so-called air curtains are used for the first time in serial production vehicle. The in-flowing air is routed into two ducts by means of openings in the outer section of the front apron. These openings are designed so that the air flows along the inside of the front apron in a closed duct to the wheel arches, where it is discharged through a very narrow opening at high speed, just passing the outer wheel flanks. The escaping air stream covers the side of the front wheels like a curtain, thereby reducing aerodynamically unfavourable turbulence around the wheel arches.
The BMW 1 Series M Coupe is fitted as standard with bi-xenon headlamps. The twin circular headlights characteristic of the brand are truncated in the upper section by an LED-fed positioning light. This is what creates the typical focussed look of the BMW 1 Series M Coupe.
With the greenhouse conveying an impression of lightness, the powerfully distinctive shoulder line and the elaborately sculpted surfaces symbolise precisely controllable athleticism from the side perspective. The wheel arches of the 2-door model bulge out especially voluminously at both the front and rear. One hallmark M feature is the chrome gill element on the front wheel arch which is particularly elongated. It bears both the side turn indicator and the M brand logo, as well as forming the starting point of the bead line running via the door openers to the rear. What is more, a vertical contour edge starts at the gill element which leads down to the side sill. Fine-tuning in the wind tunnel has also shaped the design of the exterior mirrors. In their basic shape they are the same as those of the BMW M3.
