Anyone had or is experiencing leaking oil pan gasket on e90? It started to leak on mine back in December 2014 and so far my oil levels are at 75%, I guess if there is a serious leaking they should be below 50% mark in 5 months. Or should i just go ahead and change it up ?
Thanks,Click here for SOLUTION
its a painful job - removal of subframe etc to get to the bolts which themselves are one time use only.
keep an eye on the oil level and replace when leaking excessively - This also gives you a headstart to start budgeting the repairs.
