Since I dont know the engine heat range for 95 japanese corolla auto transmission, I just wanted to check if Bosch 4 tip plugs are compatible with it?
bro i have nissan sunny 97 1.6 16valve that is not efi its pick is good on cng but can any one told me abt those bosh plugs and some gud plug wires that can more affective. and how much cost it and 4rm i get those in rwp/islamabad
Anyone?
Well I Won't Recommend If You Don't Know Heat Range....Better Get Iridium...That Will Be More Good
Stock One Comes Are Denso K16R-U11 And Denso IK16 Is Its Iridium.....!!
In NGK...Stock Ones Are BKR5ES Where As NGK Iridiums For It Are BKR5EIX....!
Mention Bosch 4 Tip Plug No So We Can Match....!!Regards
ok, I'll confirm you the bosch 4 tip plug number.
About Iridium, wont these be expensive? Bosch 4 tip are costing me Rs 1250
Also, do you know any other 4 tip plugs (easily available) that match the heat range of this 95 corolla?
