Bosch high performance puller fans with custom made shroud.
- High rpms, silent design, ideal for high performance/turbo charged engines.
- Fans made in Germany/US, no problem, damage, trouble whatsoever.
- Custom made solid structure MS shroud, no vibration or compromise.
- Shroud made to fit 92-2002 Accord radiators, can be altered easily to work with most of the wide radiator designs.
- Installed once, for an hour of test run, that's it. No local use or abuse.
Fans came with original resistor to run at high/low speed.
Size:
17x27x3.5" All sizes, especially depth, can be easily adjusted according to specific requirements.
I'll throw in a very thick wired, high output relay/fuse box, to sweeten the deal.
(High output Starter motor and ABS relays, 60amp fuse)
Demand: 8,000
ONO
Contact: PM or email.
Disclaimer:
These are very high performance fans for high demands, they're quite power hungry and nosier than most of your cars at idle. So do your homework before any decision; I personally wouldn't install them with some car's stock 50-ish amp battery/generator setup.
I would only offer a spin-check at pick up. Delivery, installation, post installation, or painting them in some particular shade of pink wouldn't be on me.
Please call me for any questions or details.
