Hi, I need suggestion in this matter as too much oil has been leaked into engine through brake vacuum boaster as master cylinder leaked oil into servo and from servo to engine, now car release black smoke on driving, and when I start it in the morning it releases white smoke. Now I have changed brake cylinder and servo as well but still oil remains in engine, which makes plugs wet and I am facing same issue, so please suggest what should be done to remove brake oil from engine?
Car is charade g100 with SZFE swap, vitx first gen eng
