so i change the brake fluid after every year, with this kit i first use this pump to get all the fluid out form the reservoir and fill up with fresh fluid till max, then i start at the further wheel and using this pump connected to the bleeder screw bleed out all the air while topping up the reservoir as necessary would that be enough?
please guide me on this isnt flushing or bleeding the same thing, in flush you get all the old fluid out you can do so by sucking out from resorvoir or by continuing to pump the pedal, then you add new fluid and bleed all the air and old fluid out till you see new clear fluid coming out of the lines?
lastly some people bleed with the engine running and some do it off, is it necessary to have the engine and brake booster running while using either technique?
