[quote="fahad.sul3man, post:7, topic:450511, full:true"]
oh that's a relief , last time i told my mechanic to change the brake fluid he insisted to change it when the hydraulic is giving problems , but still i will make him change it because it's more than 2 years now, thank you guys.
[/quote]
welcome and brake oil absorbs moisture and must be changed every two years, waiting till problem occurs would mean a expensive bill but make sure its done properly, start with the rear most passenger wheel first than rear driver wheel then passenger wheel and then driver wheel, dont bleed in air but attach a pipe into a jar already containing brake fluid and holding it higher than a bleed nipple so that no air is sucked while bleeding. its a important procedure thats why BMW dewan and shahnawaz have dedicated automated machines where the machine itself bleeds each nipple in meeting the wheel and sucks and refills the reservoir automatically and it takes only a few minutes.
