i have suzuki alto vxr, one right hand (driving side) brake light is not working. what could be the reason.
If both lights are not working than, break light switch is out of order. Break light switch is located under brake paddle. check the switch first than the wire
dear Ishtiaqone brake light is working only right hand sided not working, can it be bulb issue
yes dear,its bulb issue or bulb holder....
my reverse gear lights are not working.what could be the reason.
Ok. it might be the switch , which is out of order. What is your car???
santro,where is the switch
First of all check bulb & holder for proper electrical contact,then check revers light switch installed on gear box.
Aap ke Gatri per Bhoot ka sayya ho gaya hai, Jadoo ho gaya hai
Lol Jokes apart!!
Bhai Bulb Fuse ho gaya ho ga!!! Itni Tention walli baat nhai, mostly Electritions can trace out the Bulb not working problem in 2-3 mints!!!
Lights not working.
Change the bulb...!!!
serious problem check brake pads, check brake oil , check wheel cylinders - stay away from light assembly & do not check the bulbs in the light that may damage the whole brake system & brake booster keep car under watch it may runaway by itself.
I wish ............... ! .... damn I only can wish You shall be President of Pakistan
My cultus 2007 brake light is not working please send me a pic of brake light fuse
