I faced the same problem in my Alto after changing it's radiator, I was running it with water first and water level was decreasing so I bought a cheap coolant and poured it in to check for possible leaks, as coolant leak can be easily detected due to it's green colour.
I found two leaks in hoses and in two connecting pipes, got them replaced and now I have spotted another leak.
I'll advise you to pour some cheap coolant to detect any possible leaks and after getting the leaks fixed, top up your radiator with a good quality coolant and some water with 50/50 ratio.
