used brembo performance brake set for saleset has front two rotors n calipers onlyrotor size 12.5inches ( pretty huge)
Asking price: 35000rscontact: 03233336699
Rare stuff man. Mind sharing the compatible rides or its a universal type?
i need to check the pcd,would be 100 or 114.3 x5
for which car and where to get brake pad for this brembo calipers?
r these for reborn ..... check n let me know
guys i need to check the pcd.as for the pads i can send someone to the market n get the availability checked.
Mehroz i have installed after market brakes on my car ,these are way too big,the ones i installed are 1.5inch bigger than oem rotors.
hey JZ, thanks for the reply btw which one u got in ur reborn and how's it compare to oem brakes? did u also change calipers with ur big rotor....do msg me the details on FB
euo r after market brakes bro,details inboxed.
pcd is 100x5
Available original Brembo pads and Brake fluids contact Imperial Motors in Saddar, Plaza Market Karachi, they have limited stock of Nao Ceramic Red Shim pads and Racing Spec Black Shim Low Met Pads for most Japanese Vehicles. Contact them at 0345-2823350.
