it just stop showing display and ofcourse i lost the all contact access including all PW numbers. so i need to buy another ph, probably another Sony 510i.
what's the going rate of 510i?
sony ericsson mobiles sucks!!! I had J200i 2 years back and faced the same problem as well as scrolling problems. Now i have Nokia and thats superb.
I wud recommend u to go for Nokia.
bad luck :S
K510i is for Rs.5750.
http://www.pakgsm.com/sonyericsson_mobile_rates.html
Btw why dont u go for Nokia ,its more reliable , just an advise
try a Nokia 6230i
i dont like switching brands. when i had basic nokia model,, why was i sold sony if nokia was good now i stay with sony.
if i buy another 510i and swap lcd screen will my old ph 510i memory will still work?
memory will still work perfectly
the display area of the phone will only be affected
@levinIf only the LCD is broken then I think you wont have no problem restoring all the information in your mobile. As all your data should be there, but you can't see it because the screen is gone. I had a similar problem with my nokia 6300. I was unable to use my phone because I literally stepped on the LCD screen. But as soon as I got it repaired my phone was back to normal. All the data was accessible. Check if your phone is in warranty or not. Otherwise, you'll have to pay to fix it. But even that is not a big issue, as LCD screens are the most common fault for all the mobiles and hence mobile repairers have back-up parts available. The expense shouldn't be more than 1.5k.
my ph went for repair 3 days back and yesterday i found out display is broken and guy cant find another display. so i thought i buy another ph of same type to swap any broken parts.
if a screen costs 1.5k,, why its not fixed? strange!
Too bad. Here everything is repairable they say. Guess you weren't as lucky as I was.
Im using Sony Ericsson K700 since last 3 years . No problems . Just a joystick problem . Im lovin it
