A few days back I recorded a vlog about the scanguage car monitor device which is a great premium obd2 reader compact auto device, some of my friends asked me to share something similar but it should be less expensive for those who can’t afford a 150$ car device in Pakistan. So I decided to make another vlog about the similar kind of car obd2 reader device but its Chinese made scanner and it shows the key readings on a small monitor. I really like this rounded shape digital meter with RPM gauges on it and it is suitable for those who don’t have the car with RPM meter.It can display the bundle of real-time information like vehicle speed, engine RPM, water temperature, voltage, instantaneous fuel consumption, average fuel consumption, single driving distance, total driving distance, driving time, turbo pressure, Air/Fuel Ratio, oil temperature. It has some feature which I like the most that is warning alarming system which is very useful in case when you cross a certain speed limit or when the coolant temperature exceeds any specific temperature limit or when your car battery voltage drop to a particular low defined voltage in device memory.
you can ask me any question if you have about this device and consider subscribing my channel if you like the vlog, Thank you!
