Lala jee let me tell u if u want a neat and geniune kind modded car who should look awesome but not a over car then put extended kits...dunt put bodykit or no sticker... and put a spoiler lip at backk..
Suspension Work=depends bushes , shocks and springs
Brakes Work=depends check shoe disks and pump
Rims And Tyres Of 16"Inch And Low Ur Car=rims around 30,000 and 20,000 tyres
tyres should be of good brand and size 215/45z profile because more low profile and big size of rim will remove comfortability will effect suspension and ur car will look like 160 at the speed of 120...
front and back geniune extended bumper's and plain side skirt with paint=around 20,000 maximum
Front And Rear Led's 1 Pair Hid In Front=depends around 20,000 and 6200 for 1 year warranty bosch Hid
Neons=depends on brand but good one 6 big rauds.. 500 per raud
Interior Polishing=depends around 1000
General Service=depends around 2000
Glow Meter Chip=depends but will be around 2000
Power SteeringWork=depends
PowerWindow Work=depends
Power MirrorWork=depends
Bolts And Mounts Check Up=depends
Rear Screen To Be Dark Tinted
And Back Door Mirror's To Be Put An Nets On it
Well Do Put A Back View Camera + A Mirror Sized And Shaped Screen At The Place Of Back View Mirror
1)Intake =3000
2)4 tip platium iridium Plugs=3000
3)Tuining=depends
4)Wires 10.5MM=5000
5)Gear Oil Check Up=depends
6)Headers =4000
7)2.5"inch Down Pipeing From Headers To End =2500
8)Exhaust =Good One U ill Find In 3500
9) Radiator Service And Water Body Checking
10) A.c Service And Checked
11) Denting Painting Work If Needed...!!!
12) For Security Put Central Locking System
13) A Theif Lock Hidden in car With Timing Which U Like..Without Once Pulling The Button Before Starting U Cannot Start A Car Or If door open it will loss the current from battery...
Pull The Button And Start The Car...Put Button At Ur Hidden Choice...
Info: Dont Think To Change Engine Or Something On Ur Car..its my opinion that u will lose alot of amount and den bhi u will not be able to maintain ur car.. run orignal engine have fun..races laga kar kya karna yaar???..ager itna hee shok hay tou u should then buy a sports car... kiunke 95 ko tez karnay ka faida nahi.. har kisi k pass tou aj kal 95 hay.. so paisa zaya hoga.. keep ur car a maintain car like ACCORD CL-9 AND MARK X... U Should Make Ur Car Luxury And Looks Decent Racing..!!! Make It Qualited..!!!
System:
1) Solid-Audio F 47 Amp =13,500 it will run to D4 woofer's
2) One Amp For 2 Spk =5000 it will run 718
3) 1 pair Kenwood 718 Spk =5800
4) 2 Pioneer 307 D4=5000 + 5000 And 2000 For Cool Lasani Basetube
5) Pioneer Headunit having usb and car option put 8gb usb in it.. unlimited songs video and audio of good format
(6) folding LCD which will cost u 6500 the coool one AVT
Let Me Show U One 95 Of Mine... Its The Same Things I Told U Above..
But This Car Is 101% Orignal
Was Parked For 9 Years
Orignally 45000 Kms
Last Year It Was Modded...Like I Told U Above
We Bought In 7 Lakh...!!! + Commission
Have Orignal Digi With Me
The One Installed On it is Also Orignal But Is Modded U Can See...!!!
Copy And Paste In URL Address Bar
https://www.pakwheels.com/xt_details.asp?CarID=57907
Watched Da Vehicle????
May Be According To You The Price Is High But The Car is Qualitied...
MASHALLA
Its So Much Comfortable More Then Reborn Because It Was Used By 1st Owner Only for 5 years in which he runned it 45000 kms and it remained park for last 9 years...
And Now Em Second owner...!!!
The Car is Checked By Honda Canal Motor's , Honda Kalma Chowk And Many Pit Stop Work Shops..
Its So Luxury And Also Fills My Shashkay.. its beats full meter... U Better Know That if Someone Have zero meter civic95 ex
and on the other side zero meter reborn then which would be the most coool one according to
everything.. And Which Would Can Spends More Years Without Being Ruined...!!!
I Am Not The One Who Thinks To Buy A Pak Made Car Reborn in 18 Lakhs..
If i had 18 lakhs and option to buy a reborn or my choice
then definetly i would do my choice...!!!
I Am The One Who Thinks To Buy 2 Qualited Vehicles In This Price
I Would Buy A Civic Eagle Eye 2007 Start Vti Oreal Prosmatic In 10 To 11 Lakhs
And In Remaining 7 to 8 Lakhs..
I Would Buy A Car Like Above 95 i Did..Or Would Buy 95 or 2001 model big lights one Civic Vti Oreal
So I Hope U Will Knew What Kind Of Things I Like To Do...!!!
My Name Is Jamal Bukhari And I Am From Lahore
My Number is 0331-7414985 U Can Msg Me And We Can Have Chat Brother...!!!
Thanks Wish U Best For Ur Ride...!!! Hope U will Like My Thinking I Mentioned Above...!!!
