Assalamualaikum everyone,
Iโm planning to build a shifter kart using a 125cc engine from a bike. The project is mainly for drifting and high-speed driving, and Iโm aiming for a proper manual transmission setup with a clutch.
I would appreciate your guidance regarding:
Complete Parts List: Where can I find all necessary parts like axles, hubs, spindles, sprockets, steering assembly, brake setup, pedals, throttle cable, kingpins, tie rods, brackets, etc?
Shops and Markets: Reliable places in Lahore primarily to buy these parts either new or used at reasonable prices.
Custom Modifications: How to handle parts that don't fit exactly (like adjusting axle width, sprocket alignment, spindle angles, bearing fits)? Should I use welding, custom fabrication, or machine shop work?
Axle and Wheel Setup: Advice on correct sizing and selecting wheels and axles that would work well with a lightweight frame and a 125cc engine.
Fabrication Support: Any recommendations for local mechanics, workshops, or fabricators who understand go-kart/shifter kart builds and can help with critical jobs like spindle mounting, frame reinforcement, or custom brackets?
I'm looking for cost-effective options and solutions, as I want to complete this project with a smart budget without compromising the performance.
Any help โ like parts recommendations, shops, fabrication advice, pictures, or experiences โ would be highly appreciated!
JazakAllah Khair. Looking forward to learning from you all.
