@Time
for RWD you do toe and heel. With the toe you press the brake and heel you accelerate untill the rear looses grip. once lost traction then just press the brake with the left foot but slightly otherwise the rear brakes will engage
with FWD you half clutch and once the tires loose grip pull hand brake, and stay their for as long as you want.
or easier you can use oil, but make sure you clean up after you are done with burnout, as the oil patch can coz accidents and harm to others.
