Oh, forgot to add that I'm going to an electrician because I'm getting a fault code and the check engine light. Need the electrician to diagnose the code, and fix the issue. The code is a real pain, as it isn't specific, and points to either the fuel system, the ignition system, the injectors, the valve timing and a couple of other things! Stupid diagnostics code number 59.
However, I have just read that my engine requires premium fuel (min 91 RON octane). This last gas tank I filled was regular fuel as the pump ran out of HOBC. So will fill it up with HOBC and see if it makes a difference to my performance loss issues and the fault code.
When is Yasir due back from Dubai? Thanks.
Rao.
