Guys I need help with Net metered on Grid Solar.
I am planning to install a 25-30 KW residential solar panel setup in 2 kanal house.
If my consumption is 15KW and i install a 25-30 KW setup will it help zero my electricity bills? My current bills in summers with full load is upto 90,000 rupees a month on one meter for 2 kanal house.
- Please advise if it is beneficial to install a 25-30 kw setup i have the space for panels. How much income can you expect from LESCO if you are using 15KW and feeding 10KW into the grid?
usually I have seen residential houses go upto 15KW max. I am planning 25-30 KW to get maximum benefit and if anything extra, then can sell it to LESCO.
If anyone has any experience with net metering selling to lesco, is it worth it or is the income negligible for such a setup?
Moreover, is it beneficial to install smaller inverters or just get 1 big inverter of 25-30 kw as some people say it is more beneficial to get 10 kw inverters and sync them.
on cloudy days would you expect 0 output? has there ever been days where your generation from solar was not enough and you had to switch to grid?
@Xulfiqar @Nabs @talhawaleed @mrdeejay @centos
@umairalizafar
