Aoa, I am using caltex 5w-40 in corolla 2007,79000 driven. It is working fine and there is no reduction problem of the engine oil. I am intending to switch the brand. please guide me which brand and grade i should choose. Thankyou
Why you intend to switch brand? If it is working fine then you should keep using it.
Sent from my LG-F400L using Tapatalk
If this oil is doing its job good then why you want to switch the oil? You should stick to it.!
Sent from my D2502 using PW Forums mobile app
i have heard that shell helix ultra is much better.
i have heard shell ultra is much better.
Need your input brothers, actually i was better off while driving the car with 10w-40 in it.
Bro shell helix ultra is 5w-40. In my point of view both the brands are same. You should continue with caltex. But if you want to change the brand you can jump to ultra without any problems.
Thanx.
i am using the same oil and happywhat is ur drain interval ?
5000km
Waste of moneyUsing highest grade synthetic oil n draining at 5000kmIf u want to stick to 5k km drain switch to semi synthetic or lower grade
I change my oil after 8 months, i beleive thats quite a long interval...
Its f9 then i guess
