can i add efi on suzuki cultus 2004 (carburetor) 3 cylinder engine?
it will cost atleast 1 lac and take a month if you want a good efi.
You can get a dumb suzuki tbi from scrap and wire it up, but then you will also need to import parts to keep it running, and it is not comparable with multipoint fuel injection
can i install the new cultus(2008-09) efi engine in 2004 cultus chassis?
yes you can, it is a good option, however it will be hard to find in scrap.
Any efi G series engine will fit almost bolt-on, g13,g15,g16 all will work well
This cultus chassis won't gonna handle g15 or g16. Also won't be having good hadling and brakes whatever possible mod you do to brakes you won't get success untill you install ABS brakes but still handling is real issue. Coilovers dropping etc won't gonna help.
@dani_kk beat that last one. š¤£š¤£š¤£
Hahahahaha na karo
What's joke in that bro. Do you have justification or proves that cultus won't roll while speeding with g16 swap.
Chassis can be reinforced. Handling can improve with good quality aftermarket suspension and good tires. ABS brakes dont mean better stopping power, it just stops you from skidding if you slam the brakes hard.
I didn't said that ABS means handling and It does have better stopping power. Can you briefly explain how you gonna reinforce chasis ? Also suspension and good tires won't do wonders in improving handling.
Bro you just said that whatever mod you do to brakes it wont be successful until you install ABS.
ABS doesnt have more stopping power
If suspension and tires dont improve handling then i give up. š¤£š¤£š¤£š¤£.
Maaro mujhay saray mujhay maaro
g16 is not very big compared to a g10. the car can handle it in stock shape as well.
Just need better brakes to handle the speed, not even abs, just slightly bigger front calipers
Boss, which jdm car's rotors and calipers you recommend for Cultus to improve it's brakes?
You got your answers š¤.
Nope they won't work well.
Then what does have more stopping power. Why most of the car using it
No answers just apnay upar se qabootar uraye ja rahy hain.
Now this is a v good question. How do we know what car braking systems are compatible. Can i install accord brakes on civics. Fielder brakes on local corolla. Whats the criteria? How to check this?
Abs means antilock braking system. When a panicked or inexperienced driver slams the brake hard the wheels lock up. Abs releases the brakes and stops it from locking. A good car with proper performance suspension and tires with no abs can stop faster than another car with abs. Tires then suspension play the biggest role in good braking. Google threshold braking. If you apply the brakes just right you may be able to stop faster than with abs. Abs is a safety tool. Doesnt improve stopping distance
