My question is if I use a Chinese turbo (ct12b) in my 1kzte engine will it work and make power as Kabili? And what about the life?Chinese turbo costing me around 36k which is brand new and kabili 75k you all are well aware it's used.I overhauled the 1kzte engine Well it's in the process just confused about the turbo and which one I should go with.Also, I would like to know which oil should I use Zic or Caltex Dello gold.
Its works fine. Even used new Chinese turbo in 80 series (1hd-fe) 2 years back. Working great till date
new chinese turbo+delo
Check if there's shaft play, I know that this will be a new turbo but it's a new Chinese turbo so quality will be okey but check the shaft play in Turbo as some of these turbos are not Properly assembled so check if there's any play in Shaft if there's play in this you have to get it re-assembled !!
Perfect choice choose (company ) SL turbo Or Turbo Maxx both are outstanding in performance and standing against high temperature and boost.I always use them in 1KD , 2KD, 1HD-FTE , 1HD-FT 2L-TE , 1KZ and all are running perfectly
I installed chinese turbo cartridge only. Costed 19000. Boost is a 1
Yes go for Chinese one
Yes Chinese turbo works great.Turbo mein kabuli wagera kuch nai hota.It depends on turbo shaft pley, and usage. Mostly kabuli turbos are abused. So it's better to go with new turbo. It works great... Just take care of oil feed adapter. Most mechanics use silicone there and block the turbo oil feed resulting in broken turbo
I dont recall this level of mental retardation when I was in Pk. - silicone on the turbo oil feed?
Yes got this problem in almost 3-4 vehicles. Turbo got broken due to this. Oem gaskets are available for oil and coolant feeds but I think Desi ustaads take turbos too easy.
you never know, A Ushtaad can do anything in his jenian habitate.
