Heyy
I have just bought Pioneer DEH-5950 ! Will it play CD RW, because i think i have not burned correctly, and i think that it should play CD RW.. What say ???????? Any suggestion !!
Reference Pic:
No...As per my experiment there are hardly some players which play Re writable disc...So burn one disc properly and you are good to go!
Is it PEH or DEH?
I had a stock pioneer player that comes in se saloon. And I used to burn mp3 cd and it played well.
Sent from my iPhone using Tapatalk
it's DEH, and on the website it says cd r / rw playback compatible....
it does. iv used this player quite some time back and should play rw without any problem
Yes, it should play if it says so. Actually sometimes there is problem with lens of our Computer's CD ROM so the disc are not burned properly.
it does play CD-RW.
I have used CD-RW of SONY, its quite good quality, how ever my Pioneer player is not reading the RW disc, though my ROCKMARS player is reading that CD RW ? Also its just playing one CD, other than that its not playing other MP3 cd. What should i do?
not sure about RW. some players support it some dont.
when using ur own burned CDs make sure that the tracks are "closed". and writing is "completed". if u know what i mean :]
previously i had pioneer pre and now i have jvc kd33 that comes with suzuku ao.Both of these can play rewritable as well as writeable cds.
It surely plays RW
check ur pre's lense. if its not playing cds properly ( which are working on other pre's ) theres a problem with the current pre. since u must have bought this used (outa production now) the pre will need cleaning.
Now its playing the all other MP3 cd's but not CD RW, but My rockmars is playing that CD RW ?
get it serviced. also check the lens. this is always the case with 2nd hand cd players. get it serviced and cleaned.
I would again stress on the following issue. If you are burning your cd in XP by simply using My Computer and you are leaving some empty space then you CD CDRW may not work.
All burned CD-R are working awesome
