yes i did in February 2016 but i had gone too far before doing stud conversion and now Engine developed Oil rings problem and blows oil like a house hold water pump
@faheem
its been almost 10 months now, i paid 500 per stud and i think cultus has 6 screws so i paid 3000 for studs and 300 to my mechanic for disassembling engine.
@syncview @margallar @argtr65 whats the catch here
to my peanut knowledge unless the head is properly torqued with block after rework, car heat up & ultimate gaskit blow occur very often @xulfiqar may suggest some 'foreign' technology of re-threading a block which MAY work a little while before block replacement is needed.
I'm not the expert, but i think something called helicoil might do the trick.
I have watched videos of helicoils and thread inserts. They are permanent solutions but not available in Pakistan.
Ps. Went to market today and whole assembly of g10a was for 55k
Sent from my XT1080 using Tapatalk
10months of summer. No hgk leaks. I think this method is fine. Ps it has 8 total on 3cyl.4 of mine require the job
yes this is what happening here. head is not getting properly torqued hence compression leakage and in end gasket kaboom
sir g sargodha me bhi pra ha g15 ekeven m13
g15/g16/g13bb/g10b all have no maintenance at all except for valve clearance adjustments after 15-20k kms.. if i were you,,i would be choosing g15 with a dizzy.even g16 is available with coils on top
What if i say its available
@Xulfiqar @syncview .... does this seem fixable with helicoil?
if helicoil is doable, you can probably get it fixed in lahore
for that I will have to send engine to Lahore2 way shipment charges + Repair charges
Installing thread inserts by drilling the boltholes over sized and then cutting new threads for the thread inserts to screw into is a very simple matter.Its better to dismantle the block prior doing this job and handover the block to any well known machining shop to perform this job.
Sir, are you familiar with common term for thread inserts these mechanics and machinists uses?i am sure they wound not understand thread inserts
Every good machinist is familiar very well with inserts.However in desi term you can say choodi walla bush(Threading bush).
Thanks a ton sir. I will try my luck and post results here. I wish it get fixed without swapping
thats great where in sargodha?
Why dont you overhaul this engine as studs are working fine
mughal autos opposite suzuki lahori autos under the flyover.one at the road near sargodha hotel opposite to trust plaza
its not just about the engine bro its about getting rid of faulty curb and some other missing vacuum pipes and valves. previous owner was a jerk.
thanks i ll give him a visit some time soon.
