[highlight]Drifting refers to a driving technique and to a motor sport involving the use of the technique. This article deals primarily with the sport. A car is said to be drifting when the rear slip angle is greater than the front slip angle, and the front wheels are pointing in the opposite direction to the turn (e.g. car is turning left, wheels are pointed right), and the driver is controlling these factors.
The basic driving techniques used in drifting are constant, though each car and driver will employ some subset of these techniques. They include:
Beginner techniques:
These techniques don't use weight tra nsition, so are typically the first thing the novice drifter learns.[8] However they are still used by the most experienced drifters, and require skill to execute properly. These techniques aim to induce a loss of traction on the rear wheels, either by locking the wheel (e-brake drift), or using enough power from the engine to break the traction force (power-oversteer and clutch kick).
Hand-brake drift:
While the clutch is depressed, the hand brake (or Emergency brake) is pulled to induce rear traction loss. As soon as traction is lost, the driver releases the clutch, depresses the accelerator, and countersteers. This technique is used heavily in drift competitions to drift large corners, or to trim the car's line mid-drift.
Power oversteer or Powerslide:
Often referred to by enthusiasts as "Drifting - Lite".[citation needed] It is usually done at the corner exit by stepping on the gas hard, to slide side ways out of the corner. It is most commonly employed by beginners because it teaches steering and throttle control without the danger of an actual entry oriented drift.
Shift lock (compression slide):
Initiated by downshifting (usually from third to second or fourth to third, and using a very fast shift) instead of braking, without rev-matching, causing the drive wheels to lock momentarily. Helpful for very tight corners, allowing the driver to approach the corner at a slower speed and lower revs, while allowing quick acceleration when exiting the corner. This technique can be very damaging to the engine if mis-used as the ECU is unable to rev limit when the engine is oversped by the rear wheels. Premature downshifters are called "Rod Stretchers"
Clutch kick:
This is done by "kicking" the clutch (pushing in, then out, usually more than one time in a drift for adjustment in a very fast manner) to send a shock through the powertrain, upsetting the car's balance. This causes the rear wheels to slip. The foot should be at an angle so the brake and gas may be pressed as well, this being needed to control speed and stop from spinning out in the drift.
Weight transition techniques:
These techniques employ a further concept of weight transition. When a vehicle has the load towards the front, the back wheels have less grip than the front, causing an oversteer condition that can initiate a drift.
Braking drift:
This drift is performed by braking into a corner, so that the car can transfer weight to the front. This is immediately followed by throttle, which in a RWD car causes the rear wheels to lose traction. FWD cars can also use this technique as it does not depend on the rear wheels being driven. In FWD cars the front wheels are not allowed to lock due to the continuous power, the rear wheels locks easily due to weight transfer and due to the general front heavy design of FWDs.
A proper mechanical limited slip differential (LSD) is almost essential for drifting.
Engine power does not need to be high, and in fact if a car has too much power, it can be very hard to handle during a drift. Each driver has their own preference, and drift cars can be found with anything from 100bhp (74kW) to 1000bhp (745kW)
@ahmadbilla
ur wrong buddy according to wikipedia
cuz engine power doesn't need to be high and infact it wud bc difficult to drift a very high hp car .... and u can use some tricks to drift FWD cars toO !![/highlight]
