How i run a non solar air cooler(220v) on solar panels. What will be the procedure and expected cost of this package. Any one who can guide on this or provide me any offer. Please mention in comments.
No. U can use inverter on Ac cooler
how much ampere does the cooler draw when it starts?
i assume you are talking about desert/room air cooler
This is normal cooler takes around 6 to 7 ampere. I have been using this on electricity but now i want to use this on solar.
Which inverter, there are of different capacity and range if you can highlight this, then do it please.
6-7 amp means about 1200 watt.
you will need an inverter of at least 2000 watt. to cater for any surges etc
Air cooler with pump, hardly takes 1-1.5 amps
Consider starting with a smaller setup and scaling up if needed.
