Salaam to everyoneI am using 2.5kv gasoline loncin generator and the question is that can I run 1.5 ton dc inverter on it or not as there are lot of power problems in Pakistan.How much amp a dc inverter need to runAny disadvantages if I run it sometime on generatorAnd low voltage problem it will work on low voltage?
It will work but temp has to be set on 26-28Cuz if the comproseor works on top load it will consume around 8-10 amperes which loncin cant provideSo better to switch all load of before turning on the A.c then switch on later
Thanks for adviceIf I only run dc inverter on generator no other load
Just set temprature to 28 But be sure that your room is already cool before turning it on on generatorI mean that airconditioner was already runningCuz if thats not the case it will draw maximum current to quickly cool the room which generator cant provide
So this is on luck that it will work or not
One of my friend is using 4kva generator and he put load of 1.5 dc inverter.two water dispensers,4 fans and 8 led bulbs
Not luck just a prevantive measure
4.5kw is producing enough amperes that are required by inverter rest load is of very less power
asalamoalaikumdear your contact no plzzz0307-7788999
Sir mry pass 3kvs ka dynamic generator hai Dc inverter 1 ton easily chal jy ga kya
Aap ko check kerna paryga ky generator ke voltage aur Hertz value variate tou nae ker rahi, agar kerti hy tou phir na chalaen... Ya phir 3 KVA ka surge protector beech may lagwa lain tou phir safe rahy ga, leken I don't recommend doing so!
I doubt 2.5 kva can handle a 1.5 ton inverter ac, as AC will reach max amperes initially. If ac has a generator mode built-in like tcl miracle then it's possible
