Asalam-o-alaikam,
I have khyber 1998 model, its AC was going good cooling wasn't outclass but it was very good for 2 person although 1 of its rubber pipe coming from compressor nd going towards condensor was also a little leak.......
but sadly few days back the bolt of compressor broke up nd AC gets off. I went to the mechanis he said that compressor will be removed nd GAS will be recharged after work nd also that pipe will be changed too.....i said ok
after removing the condensor he said u should change the condensor as it has got hard......although it was genuine condensor thora ganda tha but dekhnay me theek tha......he forced me alot that u should change the condensor otherwise the compressor will get hot. anyhow i changed the condensor nd installed japanese condensor of 3500.
The air pressure was also low so i said colling box ki service b krdo, on removing the cooling box it was alot much blocked with mud. he serviced the box using acid and water nd then he said made new holes in the grills of box using some pointed pen type thing... it got the orignal grills to break but made new full open holes of the air to move...
then he fitted the AC recharged the GAS but the AC was just normal even coling got worse it was far too better before, even on the 2nd day the new pipe he installed got brust...... the mechanic said it was due to electrical prob which causes the condensor fan to get off. anyhw i recharged the gas but still AC is just a trouble nd danger of loosing the compressor, even the same mechanic now saying that compressor is weak thats why cooling theek ni... the reason he gave is that k compressor ki pully hath say b ghoom rahi hai halam k isko hard hna chahiye.........
PLZ PLZ PLZ help me regarding this i am very worried about all the situation, i live in wah cantt near islamabad also give me some suggestion regarding a good AC mechanic, menay AC chek krwaya hai wah me kuch mechanics say nd they checked AC externally from pipes nd they said k AC theek hai but andar cooling ni hti nd AC 2 hr b chalta rahay to trip ni hta
