A/C System Kuch Ziada He Acha Hogaya... Check the Readings...Little Icing Is Ok But Too Much Is NO NO...Danger To Compressor..Al-Fatiha Alert.....
0.75 Compressor Can Pull How Much Vacuum = 3 CFM Vacuum Pump....Can Be Compared When You use Them And Feel Suction..
You WILL NEVER Get Good Suction From These Compressor As They Are Not Vacuum Pumps ...
Nitrogen Is Good For Removing Any Moisture In Line If You Have Maathaa Vacuum Pump As Like Your Mech Have ....!
Else A Good Vacuum Pump Vacuums Deep Remove It All W.o Any Issues....Unfortunately I Never Came Across Any AUTO A/C Shop Or Even Commercial Installers (SPLIT) Type Who Use Vacuum Pump....
