LOW Side = Fat Line ....Its Called Suction Line Also Usually 1/2" On Splits (1-1.5 Ton)
High Side = Thin Small Line.....Its Called Pressure Side Line Also Usually 1/4" On Splits (1-1.5 Ton)
You Can Go Through Videos On Youtube To Assist You .....Just Be Well Informed And Do Your Homework Before Installing Or Charging Yourself....! Get Yourself Proper Tools Like Manifold Gauge-set Vacuum Pump Charging Lines And Thermometer Flaring tool Line Cutter Reamer....
Keep In Mind Refrigerants Ain't Cheap And Releasing Them In Air Damages Ozone Layer.. So You Have A One Good Chance To Get It Done Right On Your Factory GAS
