good one cane of 1 kg will be near 800. Will be enough for your car. It will take some 300 grams or so not sure though
Never get the small cans, they don't have a reliable connection when you tap.. Very high chances of sucking in air/moisture during charge.
Sent from my VS980 4G using Tapatalk
Few have proper connection tab. Few chinese ones dont have proper system.
Again asking @admin why is this thread not sticky?
@hash4u please post resistance value of the compressor magnet that was removed.
Yes air conditioning stopped while travelling on motorway suddenly
Please guide how do i do that?
@hash4u just use a multimeter and set resistance to lowest range. Then attach meter probes to either wire of magnet with good connection and note resistance.
R134a pt chart should be followed when engine off?
Can a bad compressor make whining sound even when not engaged and cause the car to loose power and cause missing or a feeling like wheels are locked suddenly. Is it okay to remove ac belt or get a simple pulley attached for the time being
The alternator and power steering pump is okay can it be some other bearing ac compressor is all ready dead
I m not talking about speed ,,jb gari 100km distance covr kr leti hy tb driving ki traf sy pani ata hy
Nops you need them to be followed with AC ON CAR ON BLOWER TO MAX DOORS OPEN
Whining noise can be due to bad bearing.
Get mechanic stethoscope and test it. That whining noise you are talking about i doubt your power steering pump is making. open the reservoir and see if there are bubbles. Also observe the noise when you turn the wheels
No noise increase or deccrease while turning the wheels fluid is up to level no bubbling seems like the compressor will get it checked this weekend. Its Metal on metal scratching sound
i have an issue with my ac switch. it used to go clicker. but now i have to put force to make it a click. or else it just bounces back. i am talking about the ac on off button on the control panel.
Which means it has to be replaced
Is the switch assembly available in market. Where can I find it in karachi
Sent from my XT1254 using Tapatalk
ac compressor is making noise even if its turned off?what are the causes can it be repaired without gas lose?
help please
