For a while i was also shocked
. The evaporator box had changed recently and i dont know if i have the old evep with us or not, as my brother took it to mechanic. I'll still see under dash for any labels.
Secondly, i have planned to evacuate the gas emptying the system and again refilling it after vacuuming. I just need to know, in process of evacuation, will i lose Compressor Oil? If yes, how to top it up and what quantity? I even dont know whether the oil is less or overfilled or accurate. How to know actual quantity?
Also, i am planning to remove the oil and refilling it again, is there any drain port for that so that i can be sure of the oil level?
Where is expansion valve installed in Cultus 2009 VXLi? Is it inside evaporator box?
And last, but not the least, does internally clogged radiator has to do anything with AC not cooling?
