1 - discharge ac compressor oil as the manual tells you, rotate the compressor clutch by hand till it ejects all oil and let it drip into a container for 30 minutes, measure that oil. - put in about 50 or 60 ml oil in the compressor and rework it by hand with compressor upright and remove that oil too (this was flushing) - now fill in the required quantity of oil - add from suction port.
2 - use digital weighing scales to weigh the gas container - do not ever charge the unit with liquid, leave the cylinder upright and let it suck in vapour only. close off the unit at 80% capacity and let the unit stabilise for 20 minutes at maximum load, then add the remaining.
