I have Civic 2000.I noticed today that car's air conditioner runs continually, and not even tripp for one second.Plz give me suggestion, whether i change AC thermostat or something else.
ac gas kab fill karwayi thi? ac cooling theek hai ?if it is continuously running on 2 or more fan blower setting then it is fine.
AC trips at a predetermined temperature regulated by thermostat switch. In case of extreme temperature, how do you expect it to trip? Have you noted the vent temperature? Is your refrigerant up to the specified value?
Ac was serviced and gas refilled in june 2019.Ac cooling is excellent, (chill mahoal).I run it on 1
I serviced and refilled refrigerant last year (june 2019).(((Ac is chilling cold)))I was casually sitting idle in my garrage, enjoying sidu moose wala on audio system,Then i suddenly noticed that ac is not tripping.Then i stand outside with bonnet open fir 20 minutes,, but ac fan was running continuously,
so what you are saying is... in a shaded place, at 1 blower speed, with bonnet open, the AC still did not trip in 20 minutes ?
Get it checked with a proper vent thermometer. Also check the thermostat switch wiring.
if ac working = chill then chk thermostat, once cabin is chilled start dropping its temperature setting to minimum cool if the ac trips thn u hv to adjust its thermostat aluminium wire jo evaporator mei jara hota h.
else change the thermostat by yourself- u can easily do this DIY
Yes exactly,, i accidentally noticed this thing,Because i owned so many cars in past , mehran, cultus, khyber, city, all these car's ac trips after around 45 seconds, then again turn on after 5 seconds,
