buy an hydrometer from motor parts market and check the specific gravity in each cell if the cells are internally short the specific gravity will be under 1.26 ( or 12.6 ) you may also check for any current drain at the battery with engine stop and key pulled out doors closed
also check if there is any aftermarket device is recently added or partially disconnected from the vehicle.
last but not least if the battery is over 11 months old and you live in cold climatic conditions using cng / lpg it is time you change the battery without any 2nd thoughts.
