Here you go Bro!!! This is from their website...
Ceramic Pro 9H is a Permanent Nano-Ceramic Paint Protective Coating that features a High Gloss finish, unmatched Super Hydrophobic Effect, Scratch Resistance*, Chemical Resistance, UV Resistance, Thermal Resistance and Anti-Grafitti. Ceramic Pro has been tested & certified by "SGS" - SGS - When You Need To Be Sure. SGS are the world's leading inspection, verification, testing and certification company.
Our pre-application protocol includes a complete inspection & correction of your vehicle paint before the coating is being applied, to remove all scratches, swrils and paint imperfections. This is a difficult, time consuming process & may include wet sanding, compouding & polishing . Pricing for this correction process will be finalized after inspection of the vehicle.
Multiple layers of our liquid ceramic coating are then applied on the vehicles paint. The layers will after some time cure and create a very hard super slick transparent shield that will protect the paint from a multitude of external elements and will maintain itself to provide you with a showroom finish for years to come.
The Super Hydrophobic & Anti-Grafiti combined result in surfaces coated with 9H to stay cleaner for longer as dirt and grime will not stick to the surface. The super hydrophobic effect of the coating will cause water to bead up and roll of the surface with any dirt and grime, the hard ceramic film also offers superior protection from damaging contamination and harsh chemicals.
9H forms a permanent bond to the paint work and will not wash away or break down. 9H can only be removed by abrasion making it a highly durable protective coating to protect your paint work for damaging contaminants.
- Permanent Protection
- Scratch Resistance* (Above 9H)
- Super Hydrophobic Effect
- Weather & UV Resistance
- Thermal Resistance (up to 750?C)
- Anti-Graffiti
- Advanced Chemical Resistance
- Oxidation & Corrosion Resistant
- High Gloss Finish
*Scratch Resistance: The unique formulation of 9H has enabled it to be multi-layered which means the thickness of the coating can be increased with additional layers allowing a thicker / harder film that will increase its scratch resistance.
There is a complete range of Ceramic Pro Products which includes;
Ceramic Pro 9H – Permanent Ceramic Protection
Ceramic Pro Light – Ceramic Pro Light Coat for High Gloss & Hydrophobic Effect
Ceramic Pro Sport – Ceramic Quick Detailer for 9H Maintenance
Ceramic Pro Textile – Protective Coating for Textiles
Ceramic Pro Leather – Protective Coating for Leather
Ceramic Pro Plastic/Rubber – Protective Coating for Plastic Trim & Rubber Parts
Ceramic Pro Rain – Hydrophobic coating for Glass
Ceramic Pro TAG – AntiBacterial Coating
Further information can be viewed at their website. It is done in Pakistan by only few experienced detailers... A single coat will last for 2 years and 10 layer protection package comes with a LIFETIME warranty.
Hope that answers your queries
