3M will leave your engine sparkling clean!
3M Foaming Engine Degreaser is a fast-acting, professional strength cleaner that dissolves dirt and grease from engines and drive train components. It is safe on most rubber and plastic parts and flushes away with water.
Keeping the engine clean is more important than you think. Greasy build-up on engine components can make it tough to diagnose a problem or perform regular maintenance. 3M Foaming Engine Degreaser removes all the dirt and oily grime from the engine to make the interior components as clean and well-maintained as the exterior.
One thorough cleaning with 3M Foaming Engine Degreaser will make future cleanings - and future engine maintenance ? easier. The foaming spray actively dissolves grease and oil that coat the engine?s moving parts and can inhibit performance. Within minutes, the engine will rinse clean without any scrubbing. There?s no need to get your hands dirty ? let 3M Foaming Engine Degreaser do all the work for you.
Spray 3M Foaming Engine Degreaser from a distance of about 8-10 inches from the surface. Apply a heavy coat and allow it to penetrate for 3-5 minutes. Rinse with water. Repeat if necessary.
Make greasy engine components shine with 3M Foaming Engine Degreaser.
16.5 oz. aerosol
