Had a lil meet up with the R18 boys at my usual spot for car products......hope you guys had luck trying to find the red emblen! A long an detailed discussion ensued with Bad_cheetah, though I didnt catch the name of your friend.......I forgot to get you guys have a look at the dudes dealership certificate. Hope you had an understanding of sealed bottles an aik number maal. Rest discussions to hoti hi rehti hain aur controversies nikalti hi rehti hain
thats the cut throat trend of business for you! Bad_cheetah the pre-soak, method of usage, you had around 80 ml, pour about 20 ml into a hand held spray bottle (popularly used by our NAI bhais as well as for ironing) or an old glint bottle an fill with approx 100 ml of water, shake the mixture, apply water to the intended place of usage spray your pre soak mitxture in engine bay, with an old cloth rub everything esp trouble spots or areas, over pipes is short everything. Scrub oil stained spots or dirty paint areas with it....key to engine detailing is to start from one side an do one peice at a time, or else you
ll just stay confused. So first spray with water,then spray the presoak onto certain area, rub it, hose off the place, soak another portion with water an the story goes on. Use only the amount you will dilute, keep the rest in the bottle undiluted........rest after usage post pics an tell us what results you get! Got me two of those Turtle Wax ICE synthetic polishes, will use tonight an review InshAllah.
Totallly forgot about TAYYAB CH, man Waseem bhai was like yeh bacha to toofan ki tarah aya, cheez pokri maal diya aur nikal gaya, aap nay time par hi pokra tha usko......glad you found your "ITCH KI DAWAI"abhi tak use bhi kar liya hoga.....kaisa raha ??
