Proper Washing & Drying Technique
Are you washing your car, or just damaging the paint?
Most of the swirl marks that disfigure your vehicle are likely caused by poor washing technique. Thorough weekly washes and careful hand-drying can be the best care you can give your vehicle. Improper techniques will cause unsightly swirls and scratches in the paint requiring compounding or polishing at the very least. You can eliminate these problems and save yourself extra work by following a few simple tips when washing and drying your vehicle.
Are you washing weekly or weakly?
Weekly washing is best because some contaminants quickly do serious long term damage to paint if they are allowed to remain. Two such organic compounds are bug remains and bird droppings. These bio-hazards contain complex proteins that bond to the surface and organic acids that penetrate and break down the surface, eating into your clear coat if not removed promptly. Weak spots in the clear coat make your vehicle susceptible to corrosion and discoloration.
Another problem contaminant is brake dust. It contains metal shavings from the rotors and adhesives used in the production of brake pads. Try to picture the dirty plume of brake dust and roadway chemicals that travels along with a moving vehicle. This fog of chemicals shower the lower portion of your vehicle with a clinging, nearly invisible mist. Brake dust itself, is highly corrosive and very sticky. Washing your vehicle weekly will remove these contaminants before they have the opportunity to do unsightly permanent damage.
Wash Tools
First Never wash in direct sunlight. Pick a shady spot. Second itâs very important to choose tools that are gentle on the paint, yet still effective at removing contamination. As a rule of thumb, sponges and mitts that are plush or have a deep nap are better than flat weave towels or dense sponges. For example, a Natural Sea Sponge has numerous deep compartments where dirt and debris can accumulate. The natural fibers themselves will not scratch the paint and they will essentially pull contamination into the spongeâs openings, away from the paint. Always use the softer side of the sponge for washing.
Microfiber wash mitts are another paint-safe option. Microfiberâs combination of polyester and polyamide make it capable of scrubbing the paint without scratching or swirling. It traps dirt and grit within the fibers rather than leaving them on the surface of your vehicle. Be sure to rinse the mitt frequently to release these particles.
Proper Washing
1. Wash the wheels and tires first. If you splash wheel cleaners or dirt onto your vehicle, you can simply wash it off as you wash your vehicle. Use a cleaner that is safe for all wheels. Agitate with a wheel brush to clean wheels without scratching. Wash each wheel and tire one at a time and rinse thoroughly before moving on to the next one.
2. Now youâre ready to wash. Letâs start with clean water and a freshly rinsed container and Microfiber Wash Mitt. Itâs important to use a car wash that is rich in lubricants. The purpose of the car wash is to remove contaminants and lubricate them so they do not scratch the paint as they slide off the vehicle. Dish detergents are not ideal because they remove protective coatings.
3. How do you prevent swirl marks? Use two buckets. Fill one bucket with soapy water and fill the other with clean water. Each time youâre ready to reload your sponge with soapy water, dip it in the clean water first, to rinse out the grit and contamination youâve just removed from your vehicle. Then dip it in the soapy water and continue washing.
4. Always rinse your vehicle thoroughly before you begin washing in order to remove loose debris. Then begin washing at the top of the vehicle. Wash down the vehicle as opposed to front to back. Remember that the lower panels are dirtiest. You want to clean the windows and the upper panels before cleaning the lower half of the vehicle so that you donât transfer grit to the top half of the vehicle. Rinse and reload your Sponge often to prevent cross-contamination. Rinse your vehicle frequently as you work, especially in hot weather.
For stubborn spots, like bugs or tar, soften the sponge, soak it in warm water for 3 minutes. Always use it with soapy water to lubricate the sponge. If you choose to use a spot cleaner, spray it on before washing and reapply wax to the treated area after youâve dried the vehicle.
5. When rinsing, you donât have to blast your car clean with the water hose. Free-flowing water (no nozzle) will allow the water to sheet off of your vehicle for a more thorough rinsing.
Drying
Never skip drying! Drying your vehicle after washing is necessary to prevent water spots. Water spots are caused by mineral deposits that etch the outline of a drop of water into your vehicleâs paint. All water has minerals, whether itâs from the hose or the sky. As the water evaporates, the minerals remain on the surface and they will eventually, invariably create water spots.
You can dry your vehicle in a variety of ways, but you want to make sure you do it quickly. Microfiber towels come in a number of sizes and they can be altered for a specific purpose.
Terry cloth towels are not recommended because the fibers can become matted and hard after repeated uses. They shed lint. They increase the chance of swirls. Compared to microfiber, they are not as absorbent and they donât last as long. Never use bath towels that have been discarded from the house. They are probably not soft or paint safe.
You may also use a genuine or synthetic chamois.
Drying Tips
1. Dry the windows and mirrors first.
2. Once the outside is dry, wipe down all your door jambs. Open the trunk and hood to wipe the jambs.
3. Dry your wheels using a towel or chamois that is designated just for this purpose. Donât use this towel on your paint to avoid cross-contamination. You may also use this towel to wipe off surfaces under the hood. Wash this towel before you use it again.
The Finishing Touch.
WAX it!!!!
