Safdar let me clear you few things.
how about using it after claying a waxed car. and then reapplying wax after using meiguars #7. id prefer doing it by hand as i dont have a buffer and nor does my car support its use. read my reply on restoring single stage paint and ull see what i intend to do
Dear you cannot claybar a waxed car.How can you? For claying the car should be washed to remove loose dirt.Forget about single stage or clear coat paint.No matter how rough the surface is.You cannot claybar on a waxed car.Reason : Waxing the car masks the bonded contaminants on it.If the surface is too rough, you just need to increase the quantity of detailer spray on both the claybar and panel you are working to ensure it produces no friction.Secondly, you can use the M07 alone, there is no harm but there is neither any benefit.Show Car Glaze is used to enhance the finish you get after correcting the paint with an abrasive polish.It's a pure polish which means it has no abrasives at all.So, using it alone will do nothing.
If you are using Cleaner Wax you need to apply it first and then seal the finish with a wax.Using wax in the first place and Cleaner Wax after it will dewax your car because Cleaner Waxes are used to remove surface contaminants.Although wax isn't a contaminant but since it is above the surface, so it will be removed.
