neglect is on behalf of the owner, youll have to shape up on that...I really did mix powder in water an it was silent....what noise are you talking about? If you are talking about the friction noise caused by over spray, then clay bar will only remove the over spray an not the paint......they are paint an clearcoat safe....dont worry about that....to make life easier for you, think of claybar like a magnet rather than an rubbing compound......my concern on claying after wax, you wax a surface, then dewax it by claying.......whats the gain?? you
ll just end up using more claying lube, puttin in more effort........again in simple terms for you, you put on a layer of wax on the contaminants, then take off that layer along with the contaminants with claybar....why?....just clay the contaminants off after the wash!!......Claybar has to be used with lube......if you use claybar without lube on any paint itll give you nightmares for as long as you live.........I'm pretty sure your car
s paint doesnt look like the trucks paint pictured above....besides the truck
s got paint on it, the edges are all good...yer paints condition is somthin else.....the primer
s peeking out everywhere......so quit puttin yerself in a turmoil over it!!! You play with that paint it`ll bite back....an you wont be happy then....
You want more oil inside the paint to reduce the amount of paint that comes off with cleaner wax?? How will more oil stop paint from coming off?? Bro what image are you conjouring in yer mind about micro abrasives?? Cleaner wax wont take yer paint off by the litres or colour your pad red in a couple of strokes......it`ll remove just a teensy weeensy amount, an if you do it light handed you wont even get colour on your pad.......
Clay bar is not agressive enough to remove oxidation at all,it may appear to "remove" some oxidation, but only the very top portion which has become completely detached from the actual paint surface. See "oxidation" in dictionary, the breaking apart of the molecular bond, etc, etc. You may wipe an "oil" type product on the surface to create an optical illusion of removing oxidations, but once the oils evaporate, the condition is still evident. (I.E, think of women's make-up)There are two ways to remove oxidation short of sanding and repainting,either to "chemically" remove the majority and then do a light polishing with a rotary buffer, correct pad, product or use an agressive compound, cutting pad and abrade it from the surface, followed by polishing with a correct polishing pad and polishing product.Hope you are satisfied now brother....if you still have some trouble, your more than welcome to come back an ask.............
Come on now, this isnt fair.........you`ve used cleaner waxes, an clay bars an all that stuff you just recommended we use with yer car ??
Banda ban jaaa Safdar!!!
