Appreciated advice. Thanks. Not to over-burden your good self, but I've been thinking since long to ask you - in the chaotic turmoil of all these products - if you kindly, and at best convenience, could list down a couple of "packages" recommended for best results in detailing, so one could chose according to ones available budget/requirement/vehicle from a range of recommended products. Just 3-5 standard packages would suffice us and each package should consist of following 2-3 things to be used in combination with each other for the great shine:
1) Pre-wax cleaner (optional)
2) Detailer/ shine enchancer
3) Carnauba Wax
I suppose only last 2 items will be widely used, since cleaning is only done occasionally, yet still do kindly suggest at least 1 good cleaner that could be standard in all packages. As for the remaining 2 items, I'd appreciate if you could take the trouble and combine a couple of things in following segments:
Rs. 1000-1500
Rs. 1500-3000
Rs. 3000-5000
Rs. 5000 +
The packages may exclude the pre-wax cleaner and only consist of other 2 combo items. 1 good suggestion for a prewax cleaner for new/old/soft/hard paint would however be appreciated.
Products should be those that you personally would have preferred to have/use within the ranges.
For the swirls, I trust Swirlx is the most recommended, so let's stick to this, if need be, in addition to above packages, so consider it an extra only, as the pre-wax cleaner.
Similarly, the optional top off with something synthetic may be excluded from the packages, though a good one here would be nice to have suggested.
You may structure a chart according to your own ranges even, I just mentioned some examples.
Hope this isn't too much to ask for at the end of Eid, I know the "hang-over" from all the meat, fats and barbeques may still be lingering on, lol!
Regards.
