The title says it all, got the itch early morning after fajar........immediately after Namaz.....went downstairs...took the car to the service station....I have the keys to it....:P.....an put the car on the ramp......took it up, diluted pre-soak, an waappasssh with the air gun splattered it all on the undercarrige.....after that the car came down while I used liquid clay on the entire car......took me roughly 30 mins to give each panel a minor rubbing an washed the whole car down......raised the lift an with a backscrubber cleaned the undercarrige, sprayed with water.....then used the air gun to dry it out.....used some left over cosmic to wax the black suspension parts, the fuel tank an the black mud shields........cleaned the inner side of the rims an tyre wall, air dryed them an applied Megs Endurance tyre gel.....that done the car came down, had another hose down an then with a coral sponge I shampooed the whole car with Turtles Ice........dried the car with my old Megs water magent mf.....an drove back home.......stage one done....car prepped for waxin.....tick.....first gave it a coat of Ice synthetic wax to seal in the clean surface.........removed by hand....an out came the rotary time for business.....used the megs soft buff finishing pad
an the 3M performance finish wax
the rotary was set to 2k rpm, an 3M applied directly to the pad......placed the pad on the panel an spread the wax, turned the rotary on an away we goooo....
