Bro this machine is under powered, itll only give you a slight advantage over hand buffing an will save you sweat an weary arms, for a beginner it
s forgivin in tiny mistakes that your bound to make like hand pressure, idle rubbing, angle, tight spots.Try a professional level grinder an make any one of the mistakes ive mentioned an youll be gettin that part painted, period.
It does stall if you put too much pressure, but then againt i argue that the point of waxing is to add on a protective layer over the surface, pressing down hard on the machine will achive what ???? Wax behter tareekay say lagti hai ??? Get the point??
Agay challo to I didnt get slips on surface, if you put a decent amount of polish evenly on the painted surface, I dont think it
ll slip. On the other hand even if it is slipping the pad is still rubbing the surface an that means the polish or wax is gettin laid....so slippin doesnt matter, drift the machine over the whole piece for what its worth. Bottom line is yer achieving what you want to do.
Hope this was helpful!
